Real Dirt Color
FS17/FS19 Mods just released
User avatar
Viper
Site Admin
Contact:
Re: Real Dirt Color
Post by Viper » Sun Mar 03, 2019 6:20 am
>>Here<<
ModHub has been pretty busy, regarding updates.
- Viper
spudman
Re: Real Dirt Color
Post by spudman » Sun Mar 03, 2019 7:03 am
>>Here<<
my mistake I said I had v 1.1.0.5 but its v1.0.0.5 so yes can see my mistake now, as with V1.1.0.2 its working thanks
User avatar
Viper
Site Admin
Contact:
Re: Real Dirt Color
Post by Viper » Sun Mar 03, 2019 1:33 pm
Glad to see you enjoying it. Thanks for sharing the pictures.
- Viper
sootysax
Re: Real Dirt Color
Post by sootysax » Tue Mar 05, 2019 7:42 am
Real Dirt color is only effecting the tracks of the Fendt 1159 MT not the rest of the body. Same for the Stara Estrela 32, only the wheels and none of the rest of the seeder.
User avatar
crimso
Re: Real Dirt Color
Post by crimso » Sat Mar 09, 2019 1:21 am
Hello I am receiving some log errors when. I am using the lates version, also If you need more info please let me know.
Log Entry
[Warning (script): Unknown entity id 101626 in method 'setShaderParameter'.
2019-03-08 20:56 LUA call stack:
2019-03-08 20:56 =C:/Users/User/Documents/My Games/FarmingSimulator2019/mods/FS19_realDirtColor/realDirtColor.lua (726) : setShaderParameter
2019-03-08 20:56 dataS/scripts/vehicles/SpecializationUtil.lua (26)
2019-03-08 20:56 dataS/scripts/vehicles/Vehicle.lua (1281) : raiseEvent
2019-03-08 20:56 dataS/scripts/network/NetworkNode.lua (98) : update
2019-03-08 20:56 dataS/scripts/network/Server.lua (58) : updateActiveObjects
2019-03-08 20:56 dataS/scripts/BaseMission.lua (1495) : update
2019-03-08 20:56 dataS/scripts/FSBaseMission.lua (1990) : update
2019-03-08 20:56 dataS/scripts/missions/mission00.lua (462) : update
2019-03-08 20:56 dataS/scripts/main.lua (1857) : update/logFile]
User avatar
Viper
Site Admin
Contact:
Re: Real Dirt Color
Post by Viper » Sat Mar 09, 2019 4:58 am
Hello I am receiving some log errors when. I am using the latest version, also If you need more info please let me know.
Let me know which vehicle is being used when this happens, and I'll look in it.
- Viper
User avatar
crimso
Re: Real Dirt Color
Post by crimso » Sat Mar 09, 2019 8:57 am
Hello thank you for your quick answer, vehicles from this MOD John Deere R-Series Pack by BC6 2.5.0 If the tyres ar getting dirty it cause huge FPS drop, If tyres are clean then no problem.
stronger
Re: Real Dirt Color
Post by stronger » Tue Mar 12, 2019 8:28 am
Hey. How do i fix the current error
Code: Select all
Error: Vehicle type 'hookLiftTruckScania' has unknown specialization 'realDirtColor'!
higgins.
Re: Real Dirt Color
Post by higgins. » Thu Mar 21, 2019 1:30 pm
im having a problem with the tryes on a couple of mods the john deer 7010 pack and a couple of fiat agri's i have converted the dirt shows up black on a couple of the tires!
User avatar
Viper
Site Admin
Contact:
Re: Real Dirt Color
Post by Viper » Sun Mar 24, 2019 11:01 pm
-I have confirmed that they do actually work. The body's change color at half the speed of the wheels/tracks btw. It can be less noticeable if the dirt amount is low. To confirm you can open your vehicles.xml in your savegame and set the dirtAmount to 1.0 then you'll be able to see the current dirt color better.
Here's the Fendt:
Full-Size
-If the tires getting dirty causes a drop in FPS after installing "Real Dirt Color" try resetting the vehicle.
Code: Select all
-The vehicle's specializations aren't 100% correct. (This includes using "parent" when defining a new vehicle type.)
im having a problem with the tyres on a couple of mods the john deer 7010 pack and a couple of fiat agri's i have converted the dirt shows up black on a couple of the tires!
-Issues like these are most likely due to improper wheel setup in the i3d file and/or how the parts are listed in the wheels.xml. For example, if you have no "innerRim" or "outerRim" parts and are only using the "tire" you will most likely have issues. Set up/split your parts, nodes and references to match how Giant's has them done (non mods), if this is done you shouldn't have any issues given they're using the right shader ("dirtColor" should be a parameter in the shader).
*A backup solution is to set the vehicle to use simpleMode, the how-to is in the "Readme.txt" file included with "Real Dirt Color".
- Viper
Post Reply
