Mud FX (Tire Particle System)
Unfinished work, Mod previews
Post Reply
User avatar
Viper
Site Admin
Contact:
Post by Viper » Fri May 31, 2019 1:31 pm
When it's raining or if the ground moisture level is high, there will be mud..
Coming Soon..
- Viper
User avatar
Rolnik410
Rookie
Re: Mud FX (Tire Particle System)
Post by Rolnik410 » Sat Jun 01, 2019 12:42 am
And maybe something like the mud that appears after rainfall would add to it
User avatar
Viper
Site Admin
Contact:
Post by Viper » Sat Jun 01, 2019 10:35 pm
This mod won't add mud to the ground itself. However it can be set up to watch for mud densities, so it would work if the map has it..
The Dirt-Filltype added by the Dirt Fill Station mod will also activate the mud particle system if it is raining.. - So you can spread it around how you like and have mud and bumpy areas where ever one desires.
- Viper
User avatar
Viper
Site Admin
Contact:
dev update
Post by Viper » Fri Jun 14, 2019 7:35 pm
This mod is heavy under construction, the Dirt Fill Station mod will most likely be combined with this as "Mud" the fill type has been created which you can create by watering down a pile of dirt. Any water trailer will work but a special one is now included which has a water particle system to simulate the flow of water out the back (plus extras). The mud will then active the MudFX system (particles, sinking into ground) regardless of rain. This way any map can have mud placed wherever one desires since theres no map editing needed. When raining the fields will become sinkable and also activate the MudFX system, along with dirt terrain...
-Unlike most wheel particle systems which use the vehicle's speed for particle speed, these particle systems use each wheel's speed which allows them to be active if the vehicle is stuck and the tires are spinning..
more pictures coming soon..
- Viper
User avatar
Viper
Site Admin
Contact:
pictures
Post by Viper » Sat Jun 22, 2019 1:57 am
- Viper
User avatar
Rolnik410
Rookie
Post by Rolnik410 » Sat Jun 22, 2019 5:19 pm
Well, I'm full of admiration, I'm waiting for the final result. :clapping:
User avatar
Viper
Site Admin
Contact:
Crawlers
Post by Viper » Sun Jun 23, 2019 6:13 am
Thanks for the motivation. Currently working on crawlers.
Full-Size
You may have noticed that there is no reverse particle system in the game when driving on dirt with crawler tracks. This is because there is no "Track Length" for crawlers which can be used as an offset from the rear. Using a general scale of [Track Width * 3] a reverse mud particle system is added for MudFX. (Longer tracks seem to still look okay due to the the length of flow from the ps.)
Full-Size
-The front of the vehicle will also be sunken when crawlers are working properly..
update*
Crawlers are now working properly..
Full-Size
Full-Size
-Note that the mud color from "Real Dirt Color" isn't present due to testing with a fake rain which doesn't activate the mud color.
- Viper
User avatar
Viper
Site Admin
Contact:
Couple more pictures
Post by Viper » Mon Jun 24, 2019 2:21 am
Mud is now able to be scooped up, and the H.U.D. icon is revealed.
Full-Size
Using the Aquatraxx to fill animal troughs..
Full-Size
- Viper
Post Reply
